Wanting to upgrade to lci style tail lights
My Ride: 2005 525i. Weisslicht angel eye bulbs and side marker lenses. Magnaflow exhaust, Black and silver carbon fiber emblems, aluminum race pedals, sport mode modification, LED interior bulbs, bumper reflector
So I finally decided to try and upgrade some more stuff on my car. It's a pre lci and the lci tail lights look so much better.
So my question is, if I buy a pair of lci tail lights, will they simply just be plug and play?
I also read something about Bruce cables. What are those for??
My Ride: E60 530d
bruce's cables make the lci taillights plug and play.
Alternatively get an LM2 if you car was built before Sept 2006 and get the adapter cables as show in this pdf.
Will require a simple bit of coding.
What headlights do you have? The LM2 will give you welcome lights as well...
My Ride: E61 525i 2005, F11 528i 2012
Model Year: 2012
If you only want to upgrade the tail lights only, then Bruce's cables are the way to go. It makes the LCI lights plug and play w/o errors and unwanted tail blinking.
If you consider upgrading also the front lights (perhaps in the future) to LCI type, then you have to consider buying a LM2 and do the upgrade of front and tail lights at once including the LM2 as per original BMW envisioned manner by using BMW upgrade cables. This also will give you some additional functionality as sanjsanj said.
socale39
09-05-2023 08:30 AM
rizwan1377
04-05-2015 05:22 PM
andymax
03-13-2015 10:51 AM
