Vertini Hennessey = Hub Rings
Old 06-05-2009 | 07:06 PM
flint's Avatar
My Ride: 2004 545i Black Graphite Metallic|Black Options:Sport Package|Premium|Cold Weather|6speed |Logic 7|Active Steering
I have been fighting a vibration issue on a set of 20" Vertini Hennessey wheels with Falken 452 tires since I got them. I have heard nothing but good things about these wheels and tires from many members on the board. I was under the impression these wheels were hub-centric and designed for the E60. I have had the wheels rebalanced by tire discounters 2 different times and road forced with no luck. I was about to give up and replace the tires as a last resort when bam! The tech askes me to come out and see something. The rim would sit on the hub but there was the smallest amount of free play if you lifted up on the tire! These wheels are not hub-centric! I called Vertini directly and they confirmed these wheels were actually designed for an E39. E60 hubs are 72.56mm. The wheel's diameter is 74.1mm, therefore I needed a 1.54mm hub ring. Tire Discounters installed them, and presto! No more vibration. Any other Hennessey owners out there having issues? Try this!
Old 06-05-2009 | 07:16 PM
DrLev99's Avatar
Common issue with after-market rims. Most are NOT hubcentric. Glad you got the problem solved.
Old 06-05-2009 | 08:07 PM
theXman's Avatar
My Ride: 2004 530i
That's right with aftermarket rims, sometimes you might get lucky without hubcentric rings and sometimes you don't. VMR is the other brand I know that makes hubcentric rims for E60s.
Happy to see that you are all set now
Old 06-05-2009 | 08:24 PM
Frank5er's Avatar
I never had problems with my Vertinis. I'm glad you got yours squared away, Flint!
Old 06-05-2009 | 08:45 PM
AKAlius's Avatar
Glad you got it worked out Rob!
Old 06-05-2009 | 08:56 PM
flint's Avatar
Yeah me too. Thanks again for all your help today.
Old 06-11-2009 | 09:13 PM
BulldogE60's Avatar
bump this back up there for more pics possibly? Considering these wheels. How much were the extra did you pay to get it right? How come others with the same wheels didn't have any problems?
*edit* found them here
http://forums.e60.net/index.php?showtopic=...ertini+hennessy
Old 06-12-2009 | 01:43 PM
flint's Avatar
I paid $150 for road force balancing and $20 for a set of Hub Rings. All is well now. Have no idea how nobody else had issues, these wheels clearly need Hub Rings.
Old 06-12-2009 | 01:54 PM
Frank5er's Avatar
When I got mine, the wheel shop installed the hub rings.
Old 07-26-2009 | 06:36 PM
edkwok99's Avatar
How strong are Hub Rings?
Quick Reply: Vertini Hennessey = Hub Rings
