Umnitza E60 Projector Headlights
Hello,
I recently purchased some headlights from Umnitza for pre LCI vehicle. My car was halogen and now my BMW SA is having trouble with the rewiring and repinning everything. Has any successfully completed the headlight install? And if so, can you give me any tips or instructions to get them to work properly.
Thanks Again
Thanks Again
What are they having trouble with? You can probably get the wiring diagram from Umnitza and go from there.
For your car, you should only have 5 pins to worry about on each side, which is simple to figure out -- even without Umnitza's wiring help. And depending on how you want to have the ballast be powered, via relay or original harness, you may or may not have to add additional ground.
which ones did you buy. their brand ones (i think) projector 60?
these ones..? Projector60 with FXR and Orion LED Angel Eyes [p60dfov2] - $699.99 : Umnitza|BMW Angel Eyes|LED Angel Eyes|Headlights|Lighting|Performance|Service|87748 66489
im interested in doing the same process your doing
We have the wiring diagram on the site and have provided the LCI/Pre-LCI/Halogen OE diagrams as well. It's basically splicing a couple of wires if your car was originally a halogen (or repinning the connector).
here's the diagram for our headlights.
umnitza
04-16-2015 04:39 PM
BYS2
03-24-2015 03:13 AM
