TPMS and Aftermarket wheels
05 545i and I was curious to know I am looking at buying some aftermarket wheels for my car and was wondering if it was necessary to have the TMPS on the new wheels?
will I get an error code if I dont install them on the new rims?
I plan on using my 124's for snow tires, so 3 to 4 months out of the year ill have a different set tires/wheels, so I wasnt sure if it would be worth the expense of buying a second set of tire pressure monitors or not.
what are other people doing?
thanks for your help guys.
My Ride: G30 M550i
Model Year: 2018
What date was your car built? (I think around March 2006 production, they changed from FTM to TPM.) Since your car is a 2005, you probably have FTM but just to be sure, the simplest way to figure out what you have is to look at the valve stems...
Do you currently have metal valve stems on your wheels? (not the caps, the actual stems)
If you do, then you have TPM and, if you change wheels, you'll have to mount sensors in the new wheels or you'll have a constant flat tire message (and you won't have the ability to automatically know if a tire is dangerously low.)
If your stems are not metal, then you have FTM. If you have FTM, then the new wheels will work fine -- no need to add any sensors, etc.
On either system, just be sure to re-initialize things (via iDrive settings menu) once the new wheels and tires are mounted, installed and set to the proper pressure.
My Ride: 2011 M3 Convertible, Alpine White/black, 6 speed
2011 535xi Tasmin Green, Venetian Beige
Thanks,
Jeff
My Ride: G30 M550i
Model Year: 2018
Originally Posted by JeffNNJ' post='534012' date='Feb 21 2008, 11:38 AM
So Rudy, what exactly do I need to buy in order to use my winter rims from my 06 550 on my 08?? Are all sensors the same and do they fit all rims and tires??
Thanks,
Jeff
Thanks,
Jeff
Thanks for your help Rudy.
I think I have FTM then as only the caps are metal. So basically I dont need to do anything with the new rims and tires other then reinitialize the system once the new rim/tires are installed? thats great, much appreciated.
My Ride: 07 BMW 525i Premium Package, Xenon Lighting Package, manual Transmission. Titanium Grey, 20% Tint around the back, 70% V-Kool on front.
Planned mods: Style 71 wheels with Toyo Proxy 4 tires, Sachs suspension upgrade, upgraded stereo, and many more to come.
Originally Posted by Rudy' post='534013' date='Feb 21 2008, 08:41 AM
The simplest thing to do is get them from a dealer or from a place like Tire Rack. I think there are different sizes available since there are so many different wheel geometries...
My BBS rim's valve stem hole is too small to use my original valve stem from my stock wheels, so I end up buying the smaller valve stem part from tirerack. It comes in either 8mm or 11mm I think (BMW one is 11mm, the BBS is 8mm).
Now my sensors are on the rears and not the fronts (I put the sensors on when I changed my rear), but idrive still gives me a total TPMS malfunction, meaning the rears don't work by themselves. Rudy, think this is normal?
I guess I will find out when I put the front sensors back on...
My Ride: G30 M550i
Model Year: 2018
My Ride: 2005 BMW 545i
So, if I have an 04 with FTM, can I add TPMs to the wheels and get the dealer to code? Is this possible?
Thanks
Chris
My Ride: G30 M550i
Model Year: 2018
Originally Posted by lmohaxx' post='534056' date='Feb 21 2008, 01:58 PM
Hey Rudy,
Thanks
Chris
Thanks
Chris
Also, if you think about it, FTM can be better since you don't have to spend any additional money on sensors if you have a winter set of wheels, etc.
Originally Posted by Rudy' post='534061' date='Feb 21 2008, 02:04 PM
I'm thinking it won't be that easy. I really don't know for sure without more research (I'll try to do some later if I can) but I have to believe there's some additional modules somewhere in the car that would have to also be installed or upgraded. I really don't think it would be worth doing because really the only benefit to having TPM is that the car will tell you which tire is low. Other than that, there's not much difference. It's possible that TPM may be a little more accurate or might warn you faster if you have a low-pressure situation (since it won't need the tire to rotate before getting a readout) but again, that's probably not worth the extra money and hassle you might run into if you try to upgrade things yourself.
