To those who've opened their headlights to install Umnitza's A
My Ride: 2007 525xi
Alrighty.. So, I'm planning on making the Angel Eye upgrade on my pre-lci 525xi.
I'm looking at this page... And it's a huge list of them. It's rather confusing which ones... Though from reading, I'm pretty sure it's one of these:
Some pointers on that part might be of help
But the real question for this thread is...
I was reading the DIY-guide for the Orion Angel Eyes. I know that you do have to.. forcefully open up the headlights in order to install the rings. The guide on Umnitza's site suggests cutting the plastic using a soldering iron. The hell??
I've used soldering irons on plastic before.. Mostly just for fun to kill whatever device it is. Not clean, lots of fumes, etc.
Surely there's a better way of getting at the inside of the headlights, is there not? I can't see why a nice precision Dremel tool wouldn't do the job 1000x better.
To those who've put these in: What'd you use to open up your headlights?
- http://www.umnitza.com/index.php?mai...oducts_id=1198
- http://www.umnitza.com/index.php?mai...oducts_id=5680
My Ride: 04 525i, 04 Dinan M3
I do not recommend using a soldering iron, it was a pain in the butt to do. I think there is a better method of just using a dremel with a cutting bit, I'll defer to someone else on that one. The fumes effed me up when I was cutting, it probably wasn't too good for me, but the mask I had wasn't effective. It is worth it though once you install it, biggest thing was make SURE you seal it correctly. It cost me alot of money because I did not put the top seal back on, and realized it a couple months later. Which resulted in 3 busted ballast I had to buy for my HID because water leaked in.
My Ride: ///M5 BEAST
+1 on this...I just ordered mine too and am currently getting my gameplan together on this...
I was thinking dremel tool as well, but I'm open to suggestions/established best practices.
My Ride: 05 545i
19" MRR GT1
Interior LED retrofit
Do not use a soldering iron. The "cut" will look like crap and be difficult to re-seal. I dremel with a small cutting wheel will yield better (slightly) results. In essence, even though the dremel looks like a "cutting" tool, the cutting wheel will essentially melt the plastic due to the high rotating speed. A buddy of mine that does headlight mods swears by the http://www.harborfreight.com/multifu...ool-67256.html.
My Ride: BMW E60
Model Year: 2016
My Ride: 2007 525xi
nomis_nehc - thanks for all your details!
I'll probably head over to Home Depot and rent me a high-end dremel for the day (or find a friend with one). Soldering Iron seems barbaric.
Placing the order for the Orion's now
But lastly... Any other suggestions/tips/words of wisdom for installing these?
My Orions came in the mail today....
ive thought long and hard about my gameplan, i am going to mix two things.... Ehssan's black-out method combined with a little F10 OEM flair...
take a look at the inspiration that i found at the dealership today.
I have no tip to give you since I still have no guts to do this mod yet but do consider applying the Euro sticker on the inside since you already have the light opened. It looks so much cleaner.
My Ride: 2007 525xi
If you don't mind me asking... What are you going to be doing as far as "a little F10 OEM flair"? I'm very curious - might even wait until you do yours before I crack mine open
I don't think he's making them anymore. Any other ways of going about acquiring those?
