is there easy way to replace whole foglight housing??
possible access to the fog light area is through the removal of the headlight...at least when I removed the headlights, I noticed that I can get easy access to the back of the light but did not pay attention to the rest of the housing section.
well that would only work on one side and not the driver side....
I took out both sides from underneith the same way you change the bulb. Two screws that were Torx 15 or 20 and then it just slides out. I had to clean mine up with a buffer and polish them. The drivers side was a little more difficult but just took another 5 minutes
blackstarr
03-05-2015 04:54 PM
alohalc
06-11-2004 01:07 PM
