SWS-8xi
I am about to do the SWS-8 Earthquake woofers and amp upgrade, and I noticed on E-bay there was someone selling the 2 Ohm version (SWSxi) instead of the normal 4 Ohm version, however when I go to Earthquake's website, I cant seem to find any data that support that Earthquake even makes and Xi or 2 Ohm version.....so I am wondering if these are legit Earthquake speakers or some knock off?????
Has anybody used these, what are your thoughts...or should I just go with the 4 Ohm version? I know our system runs 2 Ohm, but just wanted to be sure these are authentic Earthquake brand.
thanks
http://cgi.ebay.com/NEW-EARTHQUAKE-SWS-8XI-CAR-SUB-8-SHALLOW-2-OHM-BMW_W0QQitemZ180320387721QQcmdZViewItemQQptZCar_Subwoofers_Enclosures?hash=item180320387721&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
thanks
My Ride: 535dA M-Sport
Carbon Black
Nasca Black leather
AFS
Comfort Access
Moonroof
Active seat vent
Xenon
Navi Prof.
Night Vision
HUD
High Gloss Shadow Line
I remember that Earthquake was going to introduce them, so these must be them.
I think this would be most interesting if you're planning to upgrade, using your OEM L7 amp. It could be usefull when you are using an amp that's 1 Ohm stable (you draw more power form the amp that way).
i think that is a wrong type of earthquake sub that you can put it in underneath the seat..
http://www.earthquakesound.com/sws.htm
if you look closely, it is circle with silver in it . but one on ebay doesnt... so it might be knock off or old version
Also....I dont have the L7 system just the standard US system (Hi-Fi for you boys across the pond)
maybe I should just contact earthquak direct about these xi's
Originally Posted by IceyTys' post='774602' date='Jan 22 2009, 10:00 AM
Exactly...that what i am worried about, why wouldnt earthquake have any infor on their website about this new sub???
...what I plan on doing is installing the new SWS-8s and powering them with a PUNCH 200...I think that should about cover my needs for some extra low end bass.
Earthquake does not advertise the 2 ohm subs on the website, but they do exist. I spoke to a very nice engineer there at some length about these.
Basically if you want to use the stock BMW amp, go 2 ohm. If you are going to install a new amp, go 4 ohm.
This seller is very good and its from whom I bought my 4ohm subs from. Becareful when using the 2ohms because many amps dont like them.
Here's what I was thinking Bruce and let me know what your thoughts are.
I was planning to replace the stock amp with a Rockford Fosgate Punch 200.2 which is both 2 and 4 ohm stable. 100w x 2 @ 2ohms or 50w x 2 @ 4ohms.
with that being said, should I go with the 2 Ohm or 4 Ohm version of the SWS-8's??
below is a link to the amp I was thinking, do you think that is enough power?
http://www.rockfordfosgate.com/rftech/libr...unch2Ch-MAN.pdf
thanks for your input
My Ride: Amethest Grey 530i--AC Schnitzer Kit all the way around--Quad Magna Flow Exhaust--20" MMR wheel 4.5 inch lip--
Icey let me know what you do and if it turns out to be worth it. i have L7 and its pretty awesome but if I can get a consider amount of base from an 8 i will do in a heartbeat!
Originally Posted by IceyTys' post='777780' date='Jan 26 2009, 08:16 PM
Hmmmm...insteresting...for some reason I always thought amps were passive when it comes to Ohm rating.
I always thought what ever the head unit was, the amp would then follow suit? And the obvious wiring config of the speakers.
