Successful e60 CIC Retrofit with Bimmer retrofit
Old 11-06-2014 | 01:56 PM
sanjsanj's Avatar
My Ride: E60 530d
Originally Posted by balbs
PM member Patrys. His store is www.bimmer-tech.net.
That's where I got mine from. He'll also do the coding for your car remotely all the way from Poland.
Here's my retrofit log:
https://5series.net/forums/e60-parts...nr-pnp-123560/
And the main retrofit thread:
https://5series.net/forums/e60-parts...ion-log-99495/
That's pretty expensive! I know someone who bought the cic kit for £700 all in, pre coded too... he's charging separately for navigation activation, voice activation
Old 11-06-2014 | 03:23 PM
balbs's Avatar
My Ride: BMW
I don't know anything about coding so the support from Patryk was a bit help. Also, while the CIC kits come pre coded, my car was not and had to be coded to accept the CIC kit.
Old 11-10-2014 | 09:15 AM
bimmerretrofit's Avatar
My Ride: 2009 X6, 2009 335i, 2011 535i
Originally Posted by bruce_miranda
if you are planning on keeping your car for 3 years or so, the retrofit is well worth it. The CCC is now showing its age, unless you are a Spectrum or Atari fan.
But get the combox with the CIC, otherwise its not worth it.
If a customer is considering CIC + Combox, it may be worth to consider NBT kit instead.
  • CIC is 2nd generation iDrive, and is the latest iDrive which is available for E-series from factory.
  • NBT is 3rd generation iDrive, and is the latest iDrive which is available for F-series from factory. We have developed an eNBT Retrofit Adapter, which allows installation of NBT into E-series.
NBT retrofit will you give you such things as:
  • 200GB hard drive instead of 80GB drive (available in CIC)
  • Combox built-in
  • Sports Display (real-time power and torque meters)
  • Faster processor (faster response speed)
  • Ability to stream video from USB in the armrest (CIC does not allow this)
  • BMW Apps
  • 3D maps
Old 11-10-2014 | 09:16 AM
And just to clarify, we definitely do coding remotely for our customers, in case if it is required after the CIC installation!
Old 11-10-2014 | 09:20 AM
balbs's Avatar
My Ride: BMW
Do you have pics of it installed and working on an E60?
Old 11-10-2014 | 09:44 AM
sanjsanj's Avatar
My Ride: E60 530d
can the F30 CID be used in the E60? Does your retrofit stop BMW dealers from being able to update the car? I've heard of people having to undo retrofits for software updates from the dealer, else they refuse to touch it...
Old 11-10-2014 | 09:45 AM
Please see this video for a demonstration of NBT in E6x:
Old 11-12-2014 | 07:48 PM
wrx5's Avatar
My Ride: 2009 530i E60 LCI
  • Combox built-in
  • BMW Apps
  • 3D maps
What about map details on HUD?
RTTI enabled?
ConnectedDrive / BMW Online?
Last but not least : the price for E60 LCI?
Old 11-17-2014 | 09:41 AM
Canada22's Avatar
My Ride: 2010 BMW 528XI, 1954 Oldsmobile Super 88 324cui
Model Year: 2010
I did this upgrade myself, without a plug and play kit.
600$ - CIC unit
200$ - CIC screen
50$ - Cables,
50$ on the emulator.
And an afternoon plug play all working. There's no need to spend 3000$ on a unit if it's programmed correctly. There are other members on here that you can ask.
Old 11-17-2014 | 10:36 AM
merun0's Avatar
My Ride: E60 2009, E92 2007, E71 2009
600$ - CIC unit
200$ - CIC screen
50$ - Cables,
Read my experience here:
https://5series.net/forums/e60-parts-accessories-mods-22/bimmer-tech-bimmerretrofit-any-other-140122/#post1551388
Don't suggest something that may cause people to end up spending more $$ in the long run. If this worked for you and a couple of other people, it does not mean it will work for every body.
Quick Reply: Successful e60 CIC Retrofit with Bimmer retrofit
