subwoofer
My Ride: Bmw 530i
Hey,
For anybody that knows bmw audio and subwoofers/amps in general; please help!?.
I got a 12" jbl gto subwoofer put into my trunk and yes i have logic 7.
Its good BUT when i turn the gain up it ridiculously vibrates, when i turn it down vibrating is gone but no bass in the audio. The installer says that this is normal as i have a stock deck (i drive) .I cannot shut off the amp/sub from the front button but thats alright as i got a switch put in at the back, but the vibrating is so crazy that u can feel it in the cabin kinda like a massage?
So i was wondering if somebody could shed some light on this?
My Ride: Gone Waiting
Originally Posted by orest10' post='746223' date='Dec 16 2008, 02:45 AM
Hey,
Originally Posted by orest10' post='746223' date='Dec 15 2008, 11:45 PM
Hey,
Any of the above could be causing your problem. Aside from the obvious when you add a subwoofer you are naturally going to add "vibration" to the car, however if its an unpleasant vibration then you have a problem.
Simplest way to figure things out is
1st - Confirm your box, woofer and amp all can work together and the limits are set correctly. If youre overpower your woofer or your box is too small thats an issue.
2nd - try turning the gain down to a normal level an folding down one of your rear seats so bass will pass into the cabin, again it may be an issulation issue
the second step is an easy test.
Finally I am not sure who wired your system up, but if they were smart they would have wired your remote wire to the factory amp so the amp would turn off when the car turns off. Sounds pretty ghetto to me that you'd have to put a switch in your car to turn off your amp. If one day you forgot to turn off the switch you'd be screwed.
GL
Awest91
09-17-2022 11:05 PM
skrelnik
09-18-2015 07:24 AM
spykes
07-10-2015 07:49 AM
bruce_miranda
04-15-2015 03:25 AM
