Style 166 with 15mm spacers installed
Old Jul 20, 2006 | 05:51 AM
alts's Avatar
My Ride: 2004 BMW 645 black sapphire metallic, 19" Style 166 (245/40 & 285/35 w 15mm spacers)
I installed 15 mm H&R spacers on the rear today. I'll post some pictures of the car before and after the installation. I think that 15 mm spacers for both rear wheels are a little bit too much, maybe should have taken 10 or 12 mm spacers, especially when comparing the proportion with the front wheels. What do you think? And yes, I know these Falken tires with 275/30 setup are too narrow for this wheel, I think that 285/30 with 10 mm spacers would have given the best result.
Allar
Before:
After:
Old Jul 20, 2006 | 06:01 AM
wowe's Avatar
My Ride: BMW 530i 05 M-technic Silvergrey whith beige dakotaleather
When comparing the proportion to the front wheels they are a little to much. But then comparing whith the rear fender it?s perfect. I am planing too put that set whith 12 mm in the rear
Old Jul 20, 2006 | 06:11 AM
gasterus's Avatar
My Ride: 645Ci black/red, Eibach springs, K&N air filter, Wetterauer ECU upgrade, Eisenmann 83mmx4 exhaust, 20" Sportec wheels-Michelin PS2 tires, Hamann front add-on lip
Allar
Before:
Attachment 21856
After:
Attachment 21857
Attachment 21858
Attachment 21859
Attachment 21860
Looks good too me I think you should go for wider tires at the rear, adding aftermarket exhaust will be nice
Old Jul 20, 2006 | 07:25 AM
rsyed's Avatar
Hi,
here is a pic with 13 mm spacers on 166:
they were pretty much aligned with the front which looked good.
i then went on and bought the 167 alloys. here is a picture and with offset 17, the pic below shows what it would look like if i used 11 mm spacers on 166:
personally - 11mm is too little, 13mm was great. i am now getting 3 mm spacers for the 167 alloys.
cheers rumman
Old Jul 21, 2006 | 01:44 AM
tprenaldo's Avatar
My Ride: Mach5 05' 530i Black Sapphire Metallic w/Auburn Leather Seats, Heated Front/Rear Seats, Cold Weather Pkg, Premium Pkg, Sports Pkg, Xenon Headlights, NAV, Mud Flaps, 20" 166 Style Rims
Model Year: 2005
Engine: N54
Allar
Before:
Attachment 21856
After:
Attachment 21857
Attachment 21858
Attachment 21859
Attachment 21860
I wish I knew what you all are talking about when you mention spacers. I've heard spacers, rings, and spigots. What's the diff between these? Will the 285/30/19s really fit, and what tire brand makes that size?
Old Jul 21, 2006 | 05:00 AM
vegastrashed's Avatar
If you don't want to bother with spacers, rings, and spigots 285/30/19s are the way to go. Michelin, Goodyear, and Toyo makes tires in that size AFAIK.
Old Jul 21, 2006 | 05:31 AM
alts's Avatar
Yes, but do you think that it's possible to mount 285 tires with 15 mm spacers?
Allar
Old Jul 21, 2006 | 08:34 AM
Allar
Hmmm... If you did that wouldn't you then be pushing out the tire beyond the wheel well?
Old Jul 21, 2006 | 10:40 AM
alts's Avatar
Yes, that's what I'm afraid of myself too. But still the car doesn't look very good when my alloys are wider than my tires. What should I do to fix the problem? Install smaller spacers and wider tire?
Allar
Old Jul 21, 2006 | 11:04 AM
Allar
I think 285s will help out. Choosing the right tire manufacturer is also a step in the right direction.
