Strange problem SAT
Old Feb 23, 2014 | 10:39 AM
Soryn14's Avatar
My Ride: BMW e60 525Da LCI White, DPF out, Front grill black, Shadow line, license plate super bright led, interior white leds;
Default Strange problem SAT
Hi guys i retrofited me too this auto trans sport 1 year half ago, and from 3 days when i want to engage in R i cant, i have to engange in N and after to R, normal i put in R from first but its enter in N.
I retrofit the sat and coded to show sport in cluster, and when i press sport the steering wheel is stiffer, i installed m5 steering wheel with functional paddles like m5 without problems 1 year ago with no problems.I don't do anything to make this, happened sudenly.Why?? help me
Old Feb 23, 2014 | 10:56 AM
constant's Avatar
By chance is your battery old or getting low? I have noticed these cars are sensitive and a run down battery causes all sorts of electrical gremlins. Does it only happen in the morning but goes away once you drive a while?
Old Feb 23, 2014 | 11:24 AM
Soryn14's Avatar
No, every time i want to engage R makes that way!
Old Feb 23, 2014 | 01:41 PM
leew88's Avatar
My Ride: E60 530i LCI N53
The ECU located under the gearshift lever could be faulty, do you have the original (non SAT) shifter/ECU box you can put back to try. You don't need to code it as its backward compatible, except that you no longer have the SPORT button anymore as this only works with the SAT gearshift ECU
Old Feb 23, 2014 | 10:02 PM
Soryn14's Avatar
I think me too to this ok i will to put original shifter back i i will try...
Old Feb 24, 2014 | 02:00 AM
Soryn14's Avatar
I installed old shifter in R works ok and N but in D when i want to engage is stuck and i can't engage in D
Update i put in the old shifter and i installed and now works, i think have to touch the metal to have ground, , i will try to install sat now.
I put back the sat and it works now i don't know what happened.
I don't know how it work the shifter because after i installed all the stuff back controller all, start the engine and when i wanted to put in D N R is blocked is stays in P. Help me
Old Feb 24, 2014 | 05:59 AM
Soryn14's Avatar
Update the connections are wrecked, i searched on internet connections but i can't find and the connector from switch is broke a little where i can find cables like this pleas
Old Feb 24, 2014 | 12:00 PM
constant's Avatar
How many wires are cut? It looks like only 1 of them on the right. I bought a used shifter assembly, and 1 of the wires were cut like that too. I stripped a little of the insulation back and melted a small amount of solder across the 2 sides of bare wire. Then I painted some liquid electrical tape on top. Works great now.
Old Feb 25, 2014 | 01:33 AM
Soryn14's Avatar
Ok i'll give it a try. thks verry much
Old Oct 12, 2014 | 10:49 AM
Soryn14's Avatar
i tryed to make how you do but i can't i don't know how to do it
cinergi
Aug 3, 2018 04:31 PM
mbatayneh
May 6, 2015 03:29 PM
Faizd
Apr 27, 2015 12:16 PM
Karlosfandango
Mar 10, 2015 09:48 AM
ranger530i
Mar 7, 2015 05:49 PM
