Sprintbooster install causes error message.
Old 05-24-2009, 02:08 PM
rick circeo's Avatar
My Ride: '06 550, Sport/Navi/etceteraetcetera
Got it, installed it, love it. But here's the issue: on the first install I put the pins in wrong and it cause a stall, then it wouldn't restart, and gave me the "Engine Malfunction. Reduced Power" message. I checked the pins and installed it correctly the second time and everything's fine, except the Engine Malfunction message won't go away. Again, everything's fine except that. Any way to simply clear that code?
Old 05-24-2009, 02:12 PM
acuteperformance's Avatar
My Ride: 14 550i
if i recall, keep driving it'll go away
Old 05-24-2009, 03:06 PM
Krozi's Avatar
I drove for 60 miles trying to get rid of the message, didn't work.
Here is what you have to do, drive to autozone, advance autoparts, etc. you get the idea. The have OBD II scan tools and will reset your code for free, or a really small charge
Old 05-24-2009, 03:19 PM
coolguy's Avatar
My Ride: 2006 525i, Premium,Cold,Xenon Packages
Try the 25sec reset thing... Put the key in, turn it one slot, then press and hold Gas pedal for 25sec and then release it.
I did this, then after a while driving the error went away.
Old 05-24-2009, 03:31 PM
Thanks to all 3 for the responses. It has not gone away today, so I will do the tranny reset, then drop by the autozone if that doesn't work.
Old 05-24-2009, 06:42 PM
ricky1329's Avatar
My Ride: 530i Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
If you disconnect that SB and everything back to normal. That means your SB should fault
Old 05-25-2009, 04:35 AM
Sooo. . . Autozone ran the codes and says it didn't show any faults (even though the "engine malfunction" light is displayed), and because of that they couldn't clear it. Any other suggestions to clear the fault code?
Old 05-25-2009, 04:40 AM
Krozi's Avatar
When they hooked up the scan tool to my car it didn't show any faults either. They tried again and then found the fault.
Old 05-25-2009, 04:52 AM
Thanks for the tip. I'll run it by again.
Old 05-25-2009, 05:03 AM
Krozi's Avatar
Just tell them top refresh the scan tool a couple of times, it should come up.
Quick Reply: Sprintbooster install causes error message.
