Sprint Booster Installation Help
My Ride: 2004 545i Sport, Premium, Cold Weather, Ipod, 35% Tinted windows
What size bit do I need to remove the screws out of the pedal? I have tried to use a Torx T8 size bit and that does not seem to work. I am afraid that I have already maybe striped one of the screws. Any help you can provide would be much appreciated.
My Ride: 2010 VW Passat Wagon 2.0l Tsi
Grey/Grey Budapest 18"
Lost to HPFP issues:
08 535i sport pkg
Lost to Dreaded E61 Sun roof leaks:
07 E61 530Xi
There are about 10 different threads in the DIY section on installation, not to mention a couple Pfds floating around.
For one thing if you are using a Torx head bit you are using the wrong tool, ..... try some Hex/Allen keys I believe #6 metric, but before that you needed to pry the cap off the top of the bolt with a knife or small flat head. Other than that you really don't need any other tools, but a razor blade can help with the carpet.
Search is your friend
http://forums.e60.net/index.php?showtopic=...rt=#entry365757
this will help
Also check one of the big group buy threads , there is a pdf in there from the maker.
this will help
DetailersDomain
Detailing Forum
05-29-2015 04:52 AM
thesalboy
04-08-2015 09:13 AM
