Spacers and Vibration
Old 03-25-2012 | 10:22 AM
karman's Avatar
Hello fellow forum members, i have BR05 Bremmer Kraft rims installed on my car for about 5 months now, and i felt no vibration. These rims came with hub-centric rings, but i just installed spacers yesterday and now i am getting a heavy vibration at 60-70 mph. i know the spacers caused the vibration but i was wondering if i need to install the hub centric rings with the spacers and if so how? spacers are only on the front for now, i want to get this vibration sorted out before i install 15 mm spacers on the back.
http://www.ebay.com/itm/2-20mm-BMW-H...item4cff2b460e
that is a link to the spacers, please if anyone can help me out i would greatly appreciate it!
Old 03-25-2012 | 10:32 AM
karman's Avatar
im guessing because i removed the hub centric rings to install the spacers, but how can i install the spacers with the hubcentric rings?
Old 03-25-2012 | 10:49 AM
healthservices's Avatar
how thick/thin is the spacer?
Old 03-25-2012 | 11:13 AM
karman's Avatar
20 mm it came with extended bolts.
Old 03-25-2012 | 12:02 PM
karman's Avatar
anyone? it rides nice and smooth at any speed below 55mph after that there is vibration
Old 03-25-2012 | 05:06 PM
Why is it you cannot put the ring on the spacer?
Old 03-25-2012 | 05:53 PM
karman's Avatar
i dont think the ring will fit? the ring fits snug on the bore of the car, and the spacer is occupying that space.
Old 03-25-2012 | 06:33 PM
spacer on the hub, ring goes on the spacer, then the wheel on the spacer
Old 03-25-2012 | 07:17 PM
karman's Avatar
i will try tomorrow, but i feel the outer diameter of the spacers will be greater than the inner diameter of the rings. therefore the rings will not fit onto the spacer's machined lip. is there a way to tell (by looking at my link) if the spacers have the same outer diameter of the e60's bore? if the outer diameter of the spacer's lip is greater than the bore of the e60 than how will the ring fit onto the lip of the spacers?
Old 03-25-2012 | 07:24 PM
karman's Avatar
i guess ill have to buy new rings, if thats the case...how can i measure the outer diameter of the spacer's lip (that is where the ring will be sitting correct?)
Quick Reply: Spacers and Vibration
