spacers for 166 m5 wheels
The 166 rim with M5 offsets will be 6mm farther out than the 124 in the rear, but you can still use a 15mm spacer with the 275 tire for max push outward. The fronts will be pushed 14mm farther out than the 124's....perfect fitment.
Yes, that is correct... per correction to my above post....10mm is the ideal spacer for the rear. I forgot they are ET28, not ET32 like my 172's.
The_Sauce
06-26-2015 07:40 PM
madein
06-06-2015 11:48 AM
bestofthebest
03-30-2015 08:12 PM
