spacer question . your opinion is needed
My Ride: 2004 530isport packagepremium packageactive steeringxenon hids20mm H&R spacers in the rear6 spd51kpurchase price , 32k back in 2006
Model Year: 2004 530i
Hello Gentlemen ~
Im in the market for some rear spacers , I want to push these babies outward.
I really want to go with the 15mm spacer.
what brand spacer would you recommend?
what type of lug nut would I need in order to have a safe amount of thread on the stud?
thanks~
![](https://img.photobucket.com/albums/v478/rezapoo/530i/e69rear.jpg)
thanks~
![](https://img.photobucket.com/albums/v478/rezapoo/530i/IMG_3635.jpg)
My Ride: E46 330, E60 550 on order: Carbon Black/Natural Brown, 6MT.
2) BMW uses bolts on the wheel, rather than nuts and studs. This will make it easier to get the correct length.
My Ride: 535d Sport, carbon black, media pack, visibility pack, grey leather, heated seats, sun protection glass, voice control, Eibach ProKit, 19" 166 style wheels, e-maps ECU remap to 325hp and 640NM, top speed limiter removed
As andy said, SCC make excellent spacers (in Germany) and the H&R ones are excellent, too.
You would ideally need bolts 15mm longer. M12x1.5, 60 degree tapered head, best with a 17 nut fitting. Iirc, standard thread length is just under 27mm, so you'll be looking at 42mm thread length on the bolts.
For a safe fastening, a minimum of 6.5 turns of the bolt is recommended.
Originally Posted by iversonm' post='439898' date='Jun 26 2007, 06:17 AM
1) Ask Tirerack. They'll get you what you need. They gave me good advice about spacers to adapt my winter setup to an E90, before I changed my mind and ordered an E60.
mind if I ask where you all got your bolts from?
I totally forgot that bmw uses bolts that go into the hub , lol...
[quote name='.:reza:.' date='Jun 26 2007, 03:17 AM' post='439853']
Hello Gentlemen ~
thanks~
I picked up H&R spacers and bolts and put them on a short while ago. Do a search on spacers and you should find my post. Anyway, I used 12mm spacers and 43mm extended bolts, swapped the front bolts to match.
http://www.turnermotorsport.com/html/show_...p;RWheelSpacers
Good luck
Hello Gentlemen ~
thanks~
Good luck
My Ride: 2006 BMW 530i Alpine White, Sport Package, 6MT, Auburn interior
2007 Acura TSX, Black on Black, 6MT, OEM Body Kit
2000 Honda CBR929RR, Yellow, Pazzo Racing adjustable brake/clutch levers, Sato rear sets, full Micron Exhaust, double bubble windscreen.
Originally Posted by monacobmw' post='439993' date='Jun 26 2007, 12:34 PM
For reasons relating to my inability to remove my 20mm rear spacers when I changed from replica #166s to OEMs, I still keep the 20mm's on the rear.
It looks pretty good. I believe that 24mm = 1 inch, so the extra 1/3rd inch more than someone with the recommended 12mm spacer is not that much.
Attachment 34352
Attachment 34352
btw, to the origal poster of the topic, rogue engineering comes with the bolts.
i remember some members having Ichiba spacers . Youll need the longer bolts which they also carry, and thier spacers are hubcentric. They are located in socal
http://www.ichibausa.com/15alwhsp7.html
spacers are spacers really. the most popular brands are like the springs that people get indecisive with, between eibach and H&R. vt used ichiba spacers when he had his 166s. for my 128s, i used 15mm spacers for them to be flushed with the rear fenders, since the previous offset was ET32. for the spacers, it all depends on what offset you have and what offset you desire to have. i remember coming across a thread earlier, there's a member selling his 12mm eibach spacers.
