Sound upgrade E61 - Earthquake SWS-8, JL HD900/5,BSW Stage 1
Old 12-19-2010, 01:59 AM
haugejan's Avatar
My Ride: BMW E61 525D 2008 m-sport
Originally Posted by NavarroOne
"I created a 4 mm spacer in MDF"
is there a need for the spacer? I'm putting in sws-8's next week and I thought it was drop and go!
I like that you put original plugs on but guess it wont make sense in my case as there's no amp in my current setup and consequently, the wires running to the current speakers under the seat come directly from the HU and wont have anything to do with the amp. Based on "Technic"'s advise, I will instead use these wires as inputs to the amp and consequently run 2 sets of wires between the trunk and the subwoofers.
Yes you need the spacer. If you have the base stereo (Not Hifi or Hifi Pro/Logic 7) you don't have any amp and the wiring come directly from the HU. You need new wiring from the amp, so there is no need to use original plugs. But you need to tap in to the signal somewhere
I also have some spacer (Machine cut) if you want to buy. PM me for more info.
incoherent
04-15-2015 04:48 PM
Glowin
04-13-2015 02:42 PM
Bunbun
03-18-2006 12:03 AM
08-12-2003 11:41 AM
06-17-2003 09:38 PM
Quick Reply: Sound upgrade E61 - Earthquake SWS-8, JL HD900/5,BSW Stage 1
