So what kind of power increase if any for these mods on a 545i?
Just curious if anyone thinks having a ram air cold intake pipe
BMC filter and RPI exhaust gives any power increase if any?
dyno pre and post mod install...let us know what you come up with...
estimate or not, secondary info has a few variables...dyno, dyno operator, even the driving style of invidual can effect the outcome measures..
also: increases in hp are not cumalative: meaning the RPI scoops are 1-2 hp increases where the RPI exhaust is ???? (not even sure what that number is, but let's say 10 hp hyporthetically), that does not translate to + 11 or 12 hp...
so your exact set up, especially since you have a self made scoop vs rpi scoop or other brand would not really apply, hence an independent dyno....motorcepts is local to you and has a dyno correct? Dyno's don't run too much....I'm actually a bigger fan of vbox measurement rather than dyno numbers, but dyno numbers tend to be the normal form of measurement...
in any case, good luck with your search, I wasn't trying to just be vague and useless with my original post...
looks like you already have everything installed, why wouldn't you want to get a dyno?
Its cool, I was just looking for some opinions thanks for your time!
ran some more 0-60 runs with Fastest Droid and GPS speed (both GPS based)and got an average of 4.988 after 6 runs that was in DS mode...and a bit of tire spin...Ill keep messing with it
socale39
09-05-2023 08:30 AM
TexaZ3
05-06-2015 09:54 AM
