:unsure: :blink: How do i install replacement bulb for sidemarker on 2004 530i?
This is what I do.
The sidemarker is like a slide in clip The sidemarker would have to be push/slide gently, to the direction of the front of the car and when uncliped or lose enough to come out, I pull it out then I take out the old bulb and replace it with the new bulb of choice. Hope this helps, remember this is what I do. So try at your own risk. |
Originally Posted by GQuK545i' post='558978' date='Apr 10 2008, 02:57 AM
This is what I do.
whats is the whites buld to put in the side marker?
Originally Posted by mos12osut' post='558981' date='Apr 10 2008, 04:09 AM
Thanks,i don't know if i can do that,cause i have a chrome putco trim on it.
Can we see a pic of that??? |
It's a very straight forward install, just push forward to depress the clip and pull it right out :)
I'd also recommend our V2 Sidemarker Bulbs if you want a xenon white or amber LED replacement. http://www.jlevistreetwerks.com/images/IMG_0643.jpg |
1 Attachment(s)
http://www.jlevistreetwerks.com/images/IMG_0643.jpg so when you turn on the turn light on, it will be white????? :confused: In HK will get a ticket if I change them to white |
Originally Posted by pinguhk' post='559558
(Post 559560)
xenon white not amber??? :confused:
