Short shifter
My Ride: 2004 530i
premium package/active steering/auto sunshade/tiag/black dakota leather/logic 7
35% tint all around
19' DPE GT7
if you have small hands and nimble fingers you can do it from inside the car.
I've done it 3 times in my car, myself and from inside. The most difficult part is trying to take the circlip out without dropping it. The best thing to do is tie some thread around it before you try to even take it out. That way it hangs off the thread when its off. Do the same when putting the circlip back on.
I wish there were some pictures around of this install...I am thinking of installing a Z4 shifter, anyone now how much they go for?
Jarek
My Ride: 05 545/6
Jarek
Jarek
Originally Posted by 545felix' post='939021' date='Jul 10 2009, 07:43 PM
there is a thread with pictures. i posted a few comments in the thread. I don't remember what the title was though.
Thanks, I found your comment, the pictures helps a bit. Does the shifter attach at 2 places? On the bottom and the middle of the shifter?
My Ride: 05 545/6
just a reminder- while yes, you can do this completely inside the car, I strongly recommend you put the front end on ramps or jack stands so that if something does happen to fall into that deep dark cavity that is the rest of the transmission tunnel, you can easily get under the car and retrieve it. Because if you do drop something and the car is on level ground....it's not fun to get it up.
Originally Posted by 545felix' post='939415' date='Jul 11 2009, 10:43 AM
the only connection, per se, is at the bottom. once you remove that clip, you have to pull the selector rod off the shift lever and then you need to twist the white carrier that the shifter is resting on 90 degrees CCW. the shifter then pulls right out.
Thanks for the advice! I think I am ready to do this...
So what do I actually have to buy from BMW? just the shift arm? Do you have a part number for the z4 3.0L shifter?
Jarek
