shadowline trim tape
My Ride: 2005 525i 6MT
here a link. i was thinking of trying it and see how it goes.
but before i order, does this just look like electrical tape? im not sure how it would be anywhere near wrinkle free around the curve on the rear doors trim..
maybe ill just give it a shot and see what exactly it is lol has anyone used or seen this before?
i used it on my car, works great, looks good, just need patience.
its not electrical tape or anything like it, its vinyl strips, probably the same vinyl people wrap their cars in. and no, it does not crease. its very stretchy
is this the same stuff your talking about? this is what i had in mind. maybe its rolled vinyl..
http://www.bimmerzone.com/BMW_Access...ADOW-TAPE.html
I went with something similar the first time I worked on this area:
http://www.bmwshadowline.com/
But recently I re-did it and just went with 3M's 1080 series. It was much easier to work with. Just me 2 cents.
That is correct.
ill look into this as well, hopefully they have a kit for window trim, and you dont have to buy per foot.
My Ride: 04 525i, 04 Dinan M3
I've gone the vinyl route and honestly I'd recommend just buying replacement trim. It looks cheap if you don't do it right. The other option could be to plastidip the trim, but you would need to take the trim off.
i just ordered some 3" wide tape and will do my best to try it. after it shows up and installed ill post pics.
FWIW, i ordered from shadowlinerim.com
After some research i have seen a few people post about it and report that there was no shrinking or bubbling in weather elements.
anyone else do this?
My Ride: BMW
Also, isn't electric tape made of vinyl....Ha ha...I've used it before going OEM. It is basically electric tape but a tad stiffer and not as stretchy.
+1000...The OEM matte shadowline is only about $260 for all eight pieces plus it's more durable. You can make a dent on the vinyl tape if you run your fingernails along them...
i have a heat gun and i do snowmobile graphic wraps every winter so this should be cake..
