Running aftermarket speaker wires into door
Old 01-27-2017 | 09:28 AM
richie281vn's Avatar
My Ride: 2006 525i
Model Year: 206
Default Running aftermarket speaker wires into door
I bought my car with speakers replaced by the previous owner. However he did not route the new speaker wires into the door but rather tap into the OEM speaker doors instead.
I just retrofitted CIC with Hifi option so I want to rerun the whole speaker wires from aftermarket amp. Has anypone done this before? I looked at the joint between the door and the body and it is very tight. I retrofitted the auto fold mirror before and am sure there is no other point to run the wire through.
Appreciate your support.
Old 02-08-2017 | 05:45 PM
KOC's Avatar
KOC
My Ride: E60
Model Year: 2016
I think you can do that with a wire.....
Attached Thumbnails Running aftermarket speaker wires into door-1453097hqnzhu2q2o947d3.jpg   Running aftermarket speaker wires into door-145313ppejotre5goim89t.jpg
Old 02-08-2017 | 05:54 PM
My Ride: 2006 525i
Model Year: 206
You mean using spare slot on the connector at the door joint? My speaker wire is 16awg and i cant fit them to the bmw connector
Old 02-08-2017 | 06:09 PM
KOC's Avatar
KOC
My Ride: E60
Model Year: 2016
Then, just go through not going to pins, my friends also did that.
Old 02-08-2017 | 11:10 PM
My Ride: 2006 525i
Model Year: 206
Thanks. Let's see if I can feed it through. How did your friend go about it?
Old 09-14-2021 | 07:31 PM
Arbuz's Avatar
My Ride: Current 2010 535xi Wagon; Past 2010 535i Sedan
Model Year: 2010
18 gauge wire should do. Make sure the insolation isn't too thick then it'll go through with ease.
