Running with 20's question
Old 04-18-2009, 05:47 PM
hoodwink33's Avatar
My Ride: '04 545I SPORTS SUPENSION DINAN CAI DINAN STAGE 2 WISH LIST: RPI SCOOPS BODY KIT NEW FEET (RIMS)
Just purchased a set of 20'' rims as follows: Front 20x8.5, 13mm off set; Rear 20x9.5, 15mm off set.
What width tire should I go with without expeiencing any issues.
With the stated off set...am I gonna have any issues as well. Thanks in advance to your responses.
Old 04-18-2009, 06:11 PM
DrLev99's Avatar
Why do people buy rims and then ask questions about fitment?
You will have to roll your rear fender and use a 275/30/20 tire if you don't want to rub back there. Anything wider back there will rub no matter what. ET17 is about the lowest you can go with a 275 (and no fender rolling) on a 9.5" rim.
You can use a 245/30/20 up front. Those wheels are fine with the offsets.
Old 04-18-2009, 06:20 PM
Breae60's Avatar
My Ride: 2011 550 AW 2005 530AW GONE
Because people don't do a search before hand and see what others have done since 2004.
Old 04-18-2009, 06:25 PM
PraiseTheLowered's Avatar
and apparently newbs think IM the asshole of the forums
Old 04-18-2009, 06:36 PM
DrLev99's Avatar
HA! What would possibly give them that idea?
Old 04-18-2009, 06:50 PM
Howitzer's Avatar
You asshole.
Old 04-18-2009, 07:36 PM
acuteperformance's Avatar
My Ride: 14 550i
same reason why ppl who have m5 mirrors and mtech kit don't have an m5.
Old 04-18-2009, 08:21 PM
ill salt the grounds upon which you live lol
Old 04-18-2009, 09:16 PM
hoodwink33's Avatar
[You will have to roll your rear fender and use a 275/30/20 tire if you don't want to rub back there. Anything wider back there will rub no matter what. ET17 is about the lowest you can go with a 275 (and no fender rolling) on a 9.5" rim.
[/quote]
I appreciate your input, normally I do my reasearch ahead of time, cuase I hate to waste my hard earned dollars. I did research on the rim and was told they would fit...but again thanks.
I forgot to mention the suspension is stock; sports. So it is not lowered. Does the same factors apply?
Old 04-19-2009, 10:38 AM
DrLev99's Avatar
Yes, your car's tires will be sticking out too far. If you never have someone in the back seat, I guess you might be able to get away with it, but it might just not "look" right as is. GL!
Quick Reply: Running with 20's question
