Rubbing really bad
Hello,
I got a 5 series 2004 BMW, got some H&R sports sprins and got me 20" rims, tires: 245/35/20 Front and 275/30/20 Back, for some reason im rubbing really bad in the front and I was wondering what would you guys recomend to get this fix, please advice, thank you
Originally Posted by jersey-kid' post='423534' date='May 11 2007, 09:53 PM
I have the same problem. I'm going to try 245/30/20 in the front since I need new tires anyway. I'll let you know if it helps.
My Ride: 535d Sport, carbon black, media pack, visibility pack, grey leather, heated seats, sun protection glass, voice control, Eibach ProKit, 19" 166 style wheels, e-maps ECU remap to 325hp and 640NM, top speed limiter removed
rubbing is most of the time an offset problem.
What are the offsets of the wheels ? (ET)
My Ride: MY2005 E60 525i M Sports
Most probably, its an offset issue ...but, if u do plan 2 buy coilovers, i recommend kw variant 2 (adjustable height and damping) ...check out the reviews...and believe me, your car won't bounce...it even feels better than the original...here's the link :
http://www.kw-gmbh.de/en/30_Products/20_KW...overs/index.php
what offset are your wheels (particularly the fronts)? it sounds like that's your problem. i'm running the same size tires and get minor rubbing in the front as well. you could either get lower profile tires (25/30 series instead of 30/35) or roll your fenders. either way should fix the problem.
