Rubbing in front *Help*
Old 07-31-2008, 11:16 AM
jimlai322's Avatar
My Ride: 2008 SG 535i
Hi Guys,
I have 20x8.5 iforged wheels with 245x35x20 inch falken tires in the front and it RUBS! It usually rubs when I am slightly turning and hit a dip. Not sure what the offset of the wheels are, but the iforged wheels are made for the e60. Can the front fender be rolled?
Old 07-31-2008, 11:25 AM
tbal's Avatar
My Ride: See sig :)
try a 30 series instead, 35 is pretty big if your car is canned. You can have the fender rolled, but Id be carefull, in most instances the paint starts to chip, crinkle...
Jim, you can get the fronts rolled. check also the hard plastic piece inside where the bumper and fender come together. that's where I was rubbing before too. Im running 245/35/20 in the front as well.
Old 07-31-2008, 11:30 AM
jimlai322's Avatar
Can I get rid of that piece? I am not even lowered and I am rubbing.
Old 07-31-2008, 11:34 AM
that piece needs to be cut or grinded down.
Old 07-31-2008, 11:52 AM
John@EuroRev's Avatar
My Ride: alpinewhite's ride
Jim, call the shop and Vincent can help you out. I will be in house today from 2-4p
Old 07-31-2008, 03:30 PM
flyingpuck's Avatar
Originally Posted by jimlai322' post='636861' date='Jul 31 2008, 12:16 PM
Hi Guys,
Rubbing in front??? Careful you don't go blind!!
Old 07-31-2008, 03:31 PM
Gene's Avatar
haha, I was thinking the same thing when I read this thread tile...
"Are you trying to watch some illegal channels Jim?"
Old 07-31-2008, 03:43 PM
Trinity Autosport's Avatar
My Ride: F10 M5
Model Year: 2013
I had the same problem. All you have to do is cut the front fenders. It still does it a little bit...you just have to be carefully and go slow when the steering wheel is turned.
Old 07-31-2008, 09:29 PM
jimlai322's Avatar
thanks to the rest of the guys. I will try to cut the fender a little bit.
Quick Reply: Rubbing in front *Help*
