1 Attachment(s)
I just put my 20's and when i got like over a bump i will just get a "slight" rub. I have the sports package, but am planning on lowering the car with H&R'S and just want to see if anyone can give me advice if it will be a constant rubbing or what not.. Thanks!
Just wanted to know if you tinted your front windshield ?
Run a search for 20s. I am pretty sure that 20s without sports package is not a problem. 20's with a sports package gives a "slight" rubbing effect like you are experiencing. I guess time will tell if will be detrimental. Maybe stifer springs would help. I suspect lowering the car without somehow carving out the wheel wells will only make matters worse.
Silver, what size tires do you have? I don't think you have the ultimate low profile tires like some people on this board do. If so, that might be the reason you're experiencing slight rubs.
1 Attachment(s)
[snapback]56246[/snapback] |
1 Attachment(s)
Originally Posted by StreetDreamz' date='Nov 14 2004, 11:09 PM
Silver, what size tires do you have?? I don't think you have the ultimate low profile tires like some people on this board do.? If so, that might be the reason you're experiencing slight rubs.
[snapback]56249[/snapback] |
1 Attachment(s)
[snapback]56247[/snapback] |
1 Attachment(s)
Originally Posted by Silver530iSport' date='Nov 14 2004, 09:42 PM
[quote name='gmartin' date='Nov 14 2004, 11:02 PM']Run a search for 20s. I am pretty sure that 20s without sports package is not a problem. 20's with a sports package gives a "slight" rubbing effect like you are experiencing. I guess time will tell if will be detrimental. Maybe stifer springs would help. I suspect lowering the car without somehow carving out the wheel wells will only make matters worse.
[snapback]56247[/snapback] [snapback]56267[/snapback] [/quote]I just got done fixing my rubbing problems. I am running 245/35/20 front and 285/30/20 rear. I had the fenders rolled. They are about 99% rub free. Are you running HRE's?? If so, I am amazed that they rub. What tire brand are you running?? |
Where in Miami are you from? And I haven't searched yet but do you have any good wheel shops you can tell me? I live in South Beach, 7th
Street and Washington. |
wat is exacly rollng fenders???is it ok 2 do that on a lease car, or is it gonna be a
problem when u put the original rims back and return the car later???? |
