Rubbing with 20 inch Miro 111s (not lowered yet)
Hey everyone just wondering if anyone has any ideas as far as what to do about clearance issues in the front. I just installed 20inch Miro 111s 245/35/20 tires all the way around. I got 9.5 wide all the way around. The car is not lowered yet. It rubs if i have passengers in the car and go over a speed bump. It rubs in the front on the inner fenders. It does not hit the actual metal lip of the fender. I know that will be an issue once i lower it but what can be done as far as rubbing the inner fender? Any ideas im sure someone has ran into this before. I refuse to keep it stock height and not lower it. I have had people tell me to pull the inner fenders out....i refuse to do that as well. Just looking for ideas, im a technician at a dealer (not a bmw dealer) so i have access to multiple tools and equipment. Just looking for the best way possible to take care of it. Thanks in advance
My Ride: 2008 550 sport with all the fixins, 07 yukon with all the fixins.
If you look at the front, it has a small tab that stick out. That is where it is hitting. Get you wheel well rolled (cost prob $80-100) Also, when mine rubbed, I had the tire well rolled, and it still rubbed, but not as much. Then I went to 20/30's instead of 20/45's and the problem solved.The 45's stick out more than the 30's. Hope that helped you out.
seven11
01-23-2017 08:32 PM
JonathonK
08-25-2015 03:30 PM
