RPI scoop install
My Ride: 09 535i Xdrive
Technology package
Premium Package
Audiophile Sound Package
My mechanic was changing a flat for me ,so I thought I would ask him to install my scoop ,purchased from a member here.
He was not able to screw down the bottom portion in as he said tHe surface was not flat.He feels it will be fine with the 2 top screws and the 3m tape underneath.Thoughts?
Jeff
Jeff
My Ride: 2008 550 sport with all the fixins, 07 yukon with all the fixins.
Can't see why he couldn't fix it. I got all mine in. Just take your time and it will work. Best wishes.
a little effort, some double sided tape to hold it in place, and a stubby screw driver and it will hold just fine....it's really not that hard to DIY either
, hardest part is removing the grill to get to the area IMO
Technology package
Premium Package
I am now wondering if I purchased a 550 model scoop which I assume is a different shape from the one made for the 535? Thanks for any advice.
Jeff
Jeff
Banned
My Ride: E60 550i
Jeff
the 550i scoop is DIFFERENT from the 535i scoop....
I installed the 550i scoop on my 550i and it works great![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
We made a little video on the install
http://www.youtube.com/watch?feature...&v=eEl5ohPXo9o
Technology package
Premium Package
Jeff
So I ran into the same problem you're describing during my install. There is *NO* way that can fit cleanly with the screws provided. It's not flat and it's actually concave/inverted at that spot and due to the way it fits right above it's nearly half and inch or more away. There's literally no clean way for the bottom part to push up against the plastic cover. You have to use a real long screw, bend the metal, or use tape/some other adhesive method to get it to stick. I'm curious how anyone could use a screw that's about 1/4th and inch and get that on.. you must have some magic tricks up your sleeve..
Technology package
Premium Package
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
Banned
My Ride: E60 550i
![Smile](https://5series.net/forums/images/smilies/imported/smile.png)
