Reverse Bulb
Has there been a reverse bulb that dosent throw out error codes and is white, not yellow. I read somewhere hoking up resistors solved the issue, but is there a built in led bulb that dosent throw out an error code. I remember purchasing license plate led bulbs from someone from here, and it didnt throw any codes, maybe there is a 921 bulb like so.
http://forums.e60.net/index.php?showtopic=...mp;#entry865757
And no, I haven't seen any solution without resistors at the moment. This is probably the cheapest / best solution. Guarantee no error message.
![Happy](https://5series.net/forums/images/smilies/imported/happy.gif)
The problem is that LEDs inherently run more efficiently than the factory bulbs so they draw less power and cause the computer to trip a bulb out warning. Resistors are really the only option with LEDs unless you find bulbs with built in resistors (I have yet to see these).
jluzbet
11-07-2015 01:25 PM
umnitza
09-02-2015 11:28 AM
