5Series.net - Forums
-   E60, E61 Parts, Accessories and Mods (https://5series.net/forums/e60-e61-parts-accessories-mods-22/)
-   -   Retrofitting high beam assist (https://5series.net/forums/e60-e61-parts-accessories-mods-22/retrofitting-high-beam-assist-137384/)
Palmi G Mar 13, 2014 11:51 AM
hello i am very interested to retrofit high beam assist to my bmw e60 i have a 2004 545 with a rain sensor and a auto dimming mirror i was wondering if it would just be this process like the video below ?
also where is the fzd module located in the e60 cars if they have one ?
Holtz Mar 14, 2014 05:00 AM
You can install FLA in your car,but only if it has xenon lights, halogen no go. The auto dimming mirror is not needed but helps you, since Can_h and Can_l is up there.
BMW-ALPINA Mar 14, 2014 02:41 PM
Is this so easy for an E60 to? *putting on the list*.. :)
pjfox23 Jun 18, 2014 05:01 PM
bumping
I'm bumping to see if anyone has more information on high beam assist.
Here is what I have done to my 2008 M5:
Installed correct mirror. Wired to K_CAN_SL and K_CAN_SH.
Changed the vehicle order to include $5AC in both the LMA and CAS.
Coded CCC_APP trace and changed VA_LONGDISTANCELIGHT to aktive.
I can see "high beam assist" in I-drive. But, the actual on/off of the high beam is still not working. What am I missing? Do I need to code the Kombi or something else?
aadriann Oct 8, 2014 09:13 PM
Hello
Anyone done this retrofit? I'd like to do on my e60 525d 2004 year of product
Will work on my car?
BMW-ALPINA Oct 9, 2014 01:11 PM
I´m waiting for my mirror with FLA. I will let you know when it is installed.
sanjsanj Oct 9, 2014 02:32 PM
There are a couple of coding options in the LMA which are only for FLA cars, maybe this needs to be activated.
BMW-ALPINA Dec 3, 2014 12:56 PM
4 Attachment(s)
Finally successful retrofitting FLA/High-beam assist in my E60. I do not like to cut in vehicle wiring and therefore chose to create a plug and play solution with a Y-split. Everything works perfect!
wrx5 Dec 3, 2014 06:56 PM
non-xenon cars cannot have this retrofit? :(
BMW-ALPINA Dec 7, 2014 02:06 PM
I dont think so. Then you have to retrofit xenon headlights! :)
Video of my FLA installed.
