Retrofitting high beam assist
Old Mar 13, 2014 | 11:51 AM
Palmi G's Avatar
My Ride: Bmw 545ia
Default Retrofitting high beam assist
hello i am very interested to retrofit high beam assist to my bmw e60 i have a 2004 545 with a rain sensor and a auto dimming mirror i was wondering if it would just be this process like the video below ?
also where is the fzd module located in the e60 cars if they have one ?
Old Mar 14, 2014 | 05:00 AM
Holtz's Avatar
You can install FLA in your car,but only if it has xenon lights, halogen no go. The auto dimming mirror is not needed but helps you, since Can_h and Can_l is up there.
Old Mar 14, 2014 | 02:41 PM
BMW-ALPINA's Avatar
My Ride: 2004 BMW E60 525dA - Comf. seat, Hi-Fi Logic7, Navi prof, carphone prof, seat ventilation, Dynamic Drive, Active steering ++ Retrofits:- 9x20 & 10x20 BMW Style 101 w/ 255/30 ZR20 and 305/25 ZR20- 35/35 H&R sport springs - M-sport package- M5 trunk li
Is this so easy for an E60 to? *putting on the list*..
Old Jun 18, 2014 | 05:01 PM
pjfox23's Avatar
My Ride: BMW M5
Default bumping
I'm bumping to see if anyone has more information on high beam assist.
Here is what I have done to my 2008 M5:
Installed correct mirror. Wired to K_CAN_SL and K_CAN_SH.
Changed the vehicle order to include $5AC in both the LMA and CAS.
Coded CCC_APP trace and changed VA_LONGDISTANCELIGHT to aktive.
I can see "high beam assist" in I-drive. But, the actual on/off of the high beam is still not working. What am I missing? Do I need to code the Kombi or something else?
Old Oct 8, 2014 | 09:13 PM
aadriann's Avatar
My Ride: bmw e60
Hello
Anyone done this retrofit? I'd like to do on my e60 525d 2004 year of product
Will work on my car?
Old Oct 9, 2014 | 01:11 PM
BMW-ALPINA's Avatar
I´m waiting for my mirror with FLA. I will let you know when it is installed.
Old Oct 9, 2014 | 02:32 PM
sanjsanj's Avatar
My Ride: E60 530d
There are a couple of coding options in the LMA which are only for FLA cars, maybe this needs to be activated.
Old Dec 3, 2014 | 12:56 PM
BMW-ALPINA's Avatar
Finally successful retrofitting FLA/High-beam assist in my E60. I do not like to cut in vehicle wiring and therefore chose to create a plug and play solution with a Y-split. Everything works perfect!
Attached Thumbnails Retrofitting high beam assist-img_3120.jpg   Retrofitting high beam assist-img_3122.jpg   Retrofitting high beam assist-img_3123.jpg   Retrofitting high beam assist-img_3143.jpg
Old Dec 3, 2014 | 06:56 PM
wrx5's Avatar
My Ride: 2009 530i E60 LCI
non-xenon cars cannot have this retrofit?
Old Dec 7, 2014 | 02:06 PM
BMW-ALPINA's Avatar
I dont think so. Then you have to retrofit xenon headlights!
Video of my FLA installed.
