Retrofit semi to full electric
Hi. I've read some post about retrofitting from semi to full electric. I have switched the seats but i've got some issues like i've seen other people have. if someone can help me where i should connect these wirings i would appreciate it alot also what to code with ncs expert to remove the restraint system later on.
pictures below https://cimg4.ibsrv.net/gimg/5series...485f352a2e.jpg im guessing the red and black wire from the seat is to be connected with the blue/white and brown/black since it's in the same wiring on the yellow connector. But i still have blue/yellow and brown wire on this picture over and the picture below i have grey/red and black wires which i believe is to be something with linbus or canbus to make the seats move with buttons (i can make them move with inpa atm) https://cimg1.ibsrv.net/gimg/5series...957a4370cf.jpg the grey/brown and grey/black is to be connected to the airbag module in b pillar but my airbag module looks like this and only has 4 connections in it which makes me all confused how i should connect these https://cimg8.ibsrv.net/gimg/5series...fd80e2024d.jpg All help is appreciated! Sincerely, a BMW lover:D |
It depends what year car, do you have heat?
Originally Posted by JuniorB
(Post 1592143)
Nobody that can help or has the diagram for how the cables should go?
I pulled an entire body harness out of my 08 535 car for a bunch of retros that I'm doing. The harness inside is almost exact from what I can see, the door harnesses are different because it's an lci car. The differences are the lci changeovers, shifter, door panels,front and rear lights. If there is something nylon want me to check, I will. The late 06 for the 07 builds ar the same as fm they hav the n52 engine. I will check the sensors and report what I find.
The seats are powered by the module under the seat, in which that is powered by head, memory, and sport, if equipt, if you want all functions to work,. I think it's 12 way, 16 if m5,or so. You can try to direct plug the seats for full power, but the heat, will not work, Power and ground should be able to full power the seat.
(Post 1592233)
If you have power, you should be able to plugs it in to the new seat. There are issues with no heat retros, but if you have heat, it's plug and play. The seat module controls all the seat functions.
(Post 1592313)
If you have full heat and memory function, then your comforts seats will work, no coding is nessasery, check the seat modules. All your functions are in the seat, that abs sensor in the pillar, shouldn't have anything to do with the seats. The seat module controls your seat functions, not the car. The car controls the heat and memory, the only seats that need wiring and coding is the active m5 seats with cooling, and sport bollosters, that's the big yellow plug.,
