Replacing roundles help?
. I got my black and white roundels ready for install but removing the old ones is hard. I insert a credit card on my hood roundel and loosen it but it still wont come out! Its now lose and I tried using a flat head left a TINY mark on my hood but I have so many chips its not a problem. The card would not even go into the trunk roundel? What is a safe easy way to remove the roundels?
My Ride: '06 550i
'84 Nissan S12 Turbo
Never tried it...but looks this would work. Looks like the straps that come on paper boxes
Or this. Habor Freight mini suction cup.....
http://forum.e46fanatics.com/showthread.php?t=779261
It's pretty easy. Just stick a flat head under it, make sure to have a towel underneath so the flat head is not touching your paint. The pins are at 9 and 3 o clock position. Just work around it, and it should come out fairly easily.
Hope you got it out, I used the tinyest flathead and put a microfiber cloth under it first before i gently pryed it up.
socale39
09-05-2023 08:30 AM
