Removing the euro-stickers from headlights
Old 10-11-2008, 04:43 PM
theXman's Avatar
My Ride: 2004 530i
I've done it once. Per Nick, you should heat it up with a blow dryer first. It'll come off easier without lifting the clear coat off the light housing. Not too sure about the clear coating thing but it was better with heat. If there is any glue left behind, just use a little rubbing alcohol and you are good to go. Hope this helps. GL
Old 10-11-2008, 06:19 PM
nicke60gre's Avatar
That's right
Just curious. Was your second installation successful, or they have built bubbles again?
Old 10-11-2008, 07:18 PM
theXman's Avatar
My Ride: 2004 530i
Originally Posted by nicke60gre' post='690815' date='Oct 11 2008, 10:19 PM
That's right
So far so good. But I have been keeping the car dry alot (i.e., out of rain), maybe this has something to do too. Will keep you posted.
Old 10-12-2008, 12:23 AM
xoeightx's Avatar
Old 10-12-2008, 12:32 AM
tbal's Avatar
My Ride: See sig :)
Taking them off should almost well be the reverse of putting them on ? Any risidue gets left over, some windex or goo gone or such will help remove that...
Old 10-12-2008, 02:45 AM
nicke60gre's Avatar
I can't believe they haven't got wet already.. How did you managed that? ....Since they have been installed correctly (with proper surface cleaning) no worries about wet or rain. That f@cking chrome material adhesive backing is dry applicable only and very sensitive when applied on minor, un-noticeable residue of silicone, wax, wet.
Once it's done correctly and have no problems so far, you will not have any bubbling problems with it. If bubbling is going to be made, it will start show-up within the first 10 days (I could see it from the 1st day)
That's why I was talking about doing a test with paper-adhesive tape (the one that car body shops are using for masking)
Apply a strip of it on the surface, press it well and and try unstick it. If surface is completely clean, you'll hear the strip making a creaking sound, what means that glue has great contact with the surface, otherwise keep cleaning and dry the surface until you hear that sound (with a new strip of tape)
This is an advice for Alkalious stickers buyers as well, which they are dry/wet applicable because they are made of PVC, not pure chrome metal like my version was.
Old 10-12-2008, 10:35 AM
southgate's Avatar
im planing on doing the same thing by bubbled up they are not bad but want new ones!!
Old 10-12-2008, 10:41 AM
mrfva's Avatar
My Ride: .
Model Year: .
Seems like a few bubblies going on in here ...
I never had a chance to order from Nick; instead
I ordered from AKAlius. Just out of curiousity,
how bad are the stickers bubbling up? Any pics?
Old 10-13-2008, 11:49 AM
southgate's Avatar
i can snap a couple pics for yall...I went down to the garage but its too dark for my stupid camera phone
Ill try tommorow after work
Old 10-13-2008, 10:43 PM
Sunny 530i's Avatar
My Ride: 2007 530i
here what mined looked like: post 353 and down
http://forums.e60.net/index.php?showtopic=...5&start=345
Quick Reply: Removing the euro-stickers from headlights
