REAR OFFSET on 19s
Old 04-05-2005, 09:56 AM
millhouse24's Avatar
Hi
What offsets are you guys running on the back of your e60
I currently have 275/35/19 in the rear with a 18offset
weird thing is its only rubbing once in awhile on the passenger side
Thanks
also Ill post better pics soon
Old 04-05-2005, 10:15 AM
E60Speed's Avatar
My Ride: 545i Mystic Blue/Black Leather Type 124 Wheels
The OEM offsets are ET:32 on a 9,5" wheel for 19"
On 275/30/19 tires
Old 04-05-2005, 10:50 AM
550i's Avatar
That's crazy that 19x9.5's rub when you can fit 20x11's on it.
Old 04-05-2005, 11:20 AM
BMW535d's Avatar
[snapback]111487[/snapback]
My thoughts exactly. Even BMW is now offering 19 inch optional wheels on the 5 series.
Old 04-05-2005, 12:11 PM
the back rim is a 9.5 with a 18mm offset
Old 04-05-2005, 12:40 PM
DR.Z's Avatar
My 128's are ET 32 in the rear.
Tire size 275 X 30 X 19
9.5 " rear no rub with 32 offset.
DR.Z
Old 04-05-2005, 12:50 PM
E60Speed's Avatar
The biggest problem is that you have 275/35 instead of 275-30 tires
You speedo is wrong and you have too much tire in the wheel well
That with the wrong offset creates rubbing
Old 04-05-2005, 12:54 PM
wolverine's Avatar
My BBS RS-GT's are 19x8.5 front with 15mm offset, 19x9.5 rear with 25mm offset. No rubbing or any problems whatsoever.
Old 04-05-2005, 06:35 PM
Guest
Guest
Posts: n/a
Originally Posted by BMW535d' date='Apr 5 2005, 02:20 PM
[quote name='550i' date='Apr 5 2005, 07:50 PM']That's crazy that 19x9.5's rub when you can fit 20x11's on it.
[snapback]111498[/snapback]
[/quote]
Yeah, but don't they shorten the axle when adding larger and wider wheels. My 540 sport has a slightly narrower tract than a non sport with narrower wheels. Presumably to allow for the wider wheels and tires.
Old 04-05-2005, 06:38 PM
markt540i's Avatar
My Ride: 2010 750Li M sport
Oops. That was me.
Quick Reply: REAR OFFSET on 19s
