Re-fitting Headlight Unit - Alignment / Seating Issues
My Ride: 535d Sport
![Angry](https://5series.net/forums/images/icons/icon8.gif)
Hi folks,
I have recently installed a LED angel eye / halo bulb to my pre-LCI E60 353d. I wont dwell on the bulbs or installation of the bulbs etc as it is working perfectly and has been extensively covered throughout the forums. I have only fitted the one at the moment as I am hesitant to remove the other side until I know how to properly re-install the first side.
In order to install them I removed the headlight unit from the car (by removing the 4 torque bolts), performed the installation of the LED bulbs then "attempted" to re-install the headlight unit back on to the car, but...... i cannot get the headlight unit to align / seat the way it was prior to removing it. It seems to sit lower and angled, and the fact the its not sitting aligned with the wing makes the light unit look squint. I know there is what looks like runners and catches for the light to slide into, and think the light unit may not be seated in these properly, but have absolutely no clue as to how to get these in, without stripping the front bumper from the car. The unit was a bit fiddly coming out, but not too much persuasion was needed to remove them.
I have searched the forum but cannot find anything at all. I have seen the below video, but this is no use as I believe he has different light units (based on the look of the units), and is not detailed enough when replacing them, they seem to fall into place.
Any help, much appreciated.
My Ride: 2006 535d Sport
Put the two bottom bolts in loosely, just enough so they don't fall out, but have a big enough gap for the headlight bracket to slide under. They don't need to be taken completely out to remove or refit the headlight. Having the two bolts in will help guide the bottom headlight brackets into place.
My Ride: 535d Sport
I'll give it a bash, and might even take a few pictures if i cant find a solution!
Cheers!
My Ride: 535d Sport
Right I've tried again and again to install the headlights so they are back to normal.
The lights sit like this when I have put them back in...
![](http://i2.photobucket.com/albums/y23/wee_chris/5%20Series/IMG_8313.jpg)
Here are the brackets that the light unit slides into.....
![Name: IMG_8308.jpg
Size: 54.4 KB](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/159419d1501523631-re-fitting-headlight-unit-alignment-seating-issues-img_8308.jpg)
and heres the rear of the light that has to slide into the above photo:
![Name: IMG_8312.jpg
Size: 59.2 KB](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/159421d1501523631-re-fitting-headlight-unit-alignment-seating-issues-img_8312.jpg)
As stated above, I cannot get the light unit to sit correctly in these slots and as a result the light is pointing upwards and sitting out of position. Can anyone help? Is this a bumper off job?
Cheers,
Chris
Cheers,
Chris
My Ride: 535d Sport
nomis_nehc, there is no way anyone could get their hand down to hold the bracket. The way the bracket is bolted onto the car, pushing it down at the back, raises the front, and when I tried that it slotted in on one side and not the other. I even had the wheel arch out to try and get my hand up into the area to hold the bracket! Still no luck....
My Ride: BMW E60
Model Year: 2016
You're just doing it wrong. The headlights I reinstalled today had to be pushed up from the bracket as well.
Like I said, stick your hand to the back, and then lift up the bracket as you're sliding in the headlight, once it's aligned, you can take your hands out from the back.
Really, you're not the first person that has encountered this problem.
My Ride: 2010 550i M sport
Ok guys. I just did both of mine last night. 2010 550i M sport
You need to have a 6 inch T6 to do this. Also a magnet with an extending handle. Available cheap at any auto parts store. Leave the inboard lower bolt as loose as possible, and remove the outboard lower bolt completely. Install the headlight favoring the inboard side making sure the lower bracket slides under the bolt. Position correctly and tighten the upper bolts and the one lower bolt. Now use the magnet to lower the lower outboard bolt into place and give a turn or so to get it started. Now use your 6 inch T6 to tighten the lower bolt. No need for tiny hands,
