Question re lowering XI on KWs
Old Jan 11, 2010 | 10:19 PM
v_therussian's Avatar
I'm reading up some more on the actual installation of the KWs and stumbled upon the following disclaimer:
"in some cases spacers may be required for installation".
Has anyone installed KW V3s on an Xi? What size spacers did you use on your OEM ET43 offset wheels? Or what offset aftermarket rims did you use?
I'm thinking if spacers are indeed required for Xi, maybe I might as well get the Breytons with ET30 front and ET35 rear offsets? And if they rub a bit, I'll just roll and pull the fenders - what do you guys think about this?
Old Jan 11, 2010 | 10:20 PM
PraiseTheLowered's Avatar
id get 10mm spacers so they are sitting around 20mm after you lower
you shouldnt have to roll either
Old Jan 11, 2010 | 10:26 PM
Originally Posted by PraiseTheLowered' post='1088761' date='Jan 12 2010, 02:20 AM
I have an Xi, E! ET20 rims would not only rub - they'll stick out like half an inch!
But yes, you're basically confirming what I thought originally - since the stock offset on my Xi is ET43, I'll get ET30 wheels in the front (which is basically same as getting 13mm spacers) and ET35 is the rear - cuz ya know, if you ain't staggered, you got no swagger
Old Jan 11, 2010 | 10:28 PM
I should also add that the statement that spacers may be required mentioned that they may be required to "clear the wheel", meaning that the KWs don't "sink" the wheels any deeper than stock, they just take up more space inside the wheel well.
Old Jan 13, 2010 | 06:00 AM
gio63's Avatar
Hi,
I have lovered my xd with H&R springs and 8x18 et 34 front - 9x18 et 30 post
Old Jan 13, 2010 | 07:24 AM
id make the wheel stick out past the fender alittle bit, its got negative camber so its not like its going to be flat and straight, itll have a nice angled look
Old Jan 13, 2010 | 09:14 PM
You see, I'm doing this first and foremost for the driving, and then looks (although, I must admit, I'm EXTREMELY partial to the looks as well), but basically I want it to be a bulletproof setup, I don't want to have to change control arms after every trip to the mountains... errr, I meant the track
Old Jan 13, 2010 | 09:21 PM
Originally Posted by v_therussian' post='1090336' date='Jan 13 2010, 10:14 PM
Firstly, "lovered" - Freud would be proud of you I'm gonna "lover" mine too hahahaha
Second... ly thanks for the info, but can you please clarify - do you experience any rubbing issues with these offsets? I'd imagine with 18s its probably not as big an issue though...
well a wider stance is always better, why do you think bmw has negative camber stock with good offsets?
wide stance, stretch and poke = awesome
Old Jan 13, 2010 | 09:26 PM
Originally Posted by PraiseTheLowered' post='1090337' date='Jan 14 2010, 01:21 AM
I'll be re-aligning everything when I get the KWs, so I'll probably set it up for the best compromise between rubber consumption and handling. Guess, worst case, I'll have to pull the fenders. I'm not dying to do it, but if it has to be done... a wider stance would look pretty hot too dammit, I can't wait already - too bad I'm not using any credit cards and have to actually save up BEFORE I buy them
Old Jan 13, 2010 | 09:30 PM
lol but when you buy it youll own it and that makes it that much better
