i got an 04 525i and i just got it lowered today and the rear seems like its kinda cambering where it angles a il, does anyone have this? would getting an alignment fix it to where the wheels will be straight up and down?
A negative camber is expected when you lower a car. I have the same issue...my rears cambered to -2 after lowering. An alignment helps a bit but they need to be aware that you want a minimal camber. I had mine aligned right after I lowered but they didnt seem to adjust the camber at all. :\
More info in this thread: http://forums.e60.net/index.php?showtopic=27701&hl= |
Originally Posted by disnikhavikta' post='346080' date='Oct 17 2006, 10:02 PM
cool thanks busta!! so when i got to a alignment place tomorrow i should tell them that i need minimal camber??does that tell them that they need to make it back to normal as much as possible?
alright coo, thanks bro!
Post some pics when you get a chance...I want to see your Seva wheels on a E60 :)
You bought the seva wheels from Carl in Miami?
