Is 1200 to 1400 a bad price on a set of lightly used OEM 166's of an M5. There are no marks or rash on the rims at all?
considering BNIB at a discounted price is ~$2200-$2400....that's a GREAT price...
That's a great price. :thumbsup:
Thanks guys. What off-set should I get for these then. 10mm?
get the M6 offset
Sorry for the newb question but since these are OEM off an M5 I presume they will come with the M5 offset so I would have to do spacers right? From what I have read I thought 10mm was the correct size.
You can do up to 15mm in the rear. 15mm will give you the most aggrssive stance. 12mm should be fine too, if you don't want it too aggressive.
Perfect. Thanks.
M5 rear offset is ET 28
M6 rear offset is ET 17 so 10 mm spacers would get you an ET 18, 12 mm would get you an ET 16 sorry, no 11mm spacer options :P |
