Pre lci to LCI upgrade options?
My Ride: 2005 525i 6MT
hello everyone,
its time for an lci facelift... starting with the headlights.
currently im pre lci halogen. i can get a good deal on lci bi xenons.. is this possible with a retrofit cable?
i can drop in a set of HID's for bulbs, im really just looking for the lci look along with the projectors. they will be receiving some custom work. (AE's and quad projectors) For now, just need to find a good used lci headlight but wasn't sure what i should be looking for if i cannot find lightly used lci halogen.
from my unserstanding its easies to go from pre lci halogen to lci halogen but is anything else doable? i don't need the actve xenon or any of that.
any help you can send me way is appreciated!
thanks
thanks
My Ride: BMW E60
Model Year: 2016
I thought I answered this for you in the PM. Yes you can go to LCI xenons (only xenons are bi-xenon), but parts alone you're looking to spend $3k; easily more than what you told me you want to spend, and that's not even including labor and coding.
Edit:
I must correct myself, actually, the above is only correct if you want to do it OEM way. It IS possible to do LCI xenons without following BMW's retrofit procedure, however, you are looking at very much custom wiring and coding work, on this side of the country, I think I am the only one that knows how to do it. Would bring the cost down by a grand or little more on parts, but still, not something anyone can do for you.
Edit:
Edit:
Edit:
i know lci halogens will work with the cable, and without coding, (*will i need a LCM2??) but wasnt sure if a retrofit cable would allow other lci lights to work without coding... my question is answered. only lci halogen swap requires no coding ive found a few other sources for retrofitting some AE's.
if all else fails ill hit you up and send them to you. if its going to be more than what i budgeted and its my only option it is what it is and ill be sending them to you
the reasons i asked is because i'm having trouble finding used lci halogens where the lenses aren't shot
i dont need to do the tails at the same time do i? can i do just the lci headlight conversion from pre lci halogen to lci halogen
My Ride: BMW 525dA 2007 pre-LCI.
This is something for you : https://5series.net/forums/e60-parts...-103684/page5/
This weekend I converted my Pre-LCI halogen to LCI xenon using the OEM wire Looms. Did both front and rear with the height sensors. Head light washers will follow so I have no problem with the vehicle inspection here which require the height sensors and the Washers. Cost is around 1000 euro using ebay parts apart from both looms.
My Ride: BMW E60
Model Year: 2016
Bill, if you actually know how long it takes and all the details involved, trust me, you'll understand that I am undercharging myself.
As for going to LCI halogens, no, you don't required LM2, or LCI tails. Check the last PM I wrote you. I basically broke it all down for you. You really are not going to find more information that what I basically digested for you.
socale39
09-05-2023 08:30 AM
ricki_
12
02-08-2020 09:50 PM
Stormcrow
12-01-2019 02:09 AM
AbyssalCreation
05-04-2015 05:30 AM
550iwa
03-27-2015 06:45 AM
