Pre-LCI and LCI Headlight Question
My Ride: E60 BMW ///M5 V10
I was wondering if it is possible to transfer the existing xenon bulbs and ignitors/ballasts from my pre-LCI headlight to an LCI headlights. Or do they require different equipment? Does anyone know?
Thanks,
Matt
Thanks,
Matt
My Ride: 2006 E60 M5 (Sepang Bronze/Natural Brown)
Eisenmann Exhaust with Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi Scoops & Block Off Plates with BMC Filters
Eibach Pro-Kit Springs
20" Breyton Race CS in Polished Silver
I am sooo following you on this subject!
I know you're dying to retrofit LCI fronts and rears on your car!
Banned
My Ride: A Car
my car is going into BMW for retrofit programming AGAIN! hopefully, it works this time. if u have D1S bulbs and ballasts, it should work. U may need an ALC and may need an LCM, also retrofit cables, wire it up to the LCM, pain in the ass and headaches. If I can easily reverse this, I wouldve done it. too late now!
Originally Posted by BMWPower06' post='1007955' date='Sep 15 2009, 01:42 AM
Yea i just bought a pair of Euro LCI tails with V3 cables from a member on here. Looking to get the headlights next, seen a bunch in the junk yards, just wondering if I can re-use my stock bulbs/ballasts/ignitors
I'm just going to pay my dealer to wire it all up and program it for me. The PDF from BMW says its a 5.5 hour job. I'd rather pay ~$700 and have my dealer do everything, than risk messing something up myself.
Thanks,
Matt
Thanks,
Matt
My Ride: BMW e60 525IA 12/2003
Thanks,
Matt
Thanks,
Matt
Hi
You don't write/informe witch date your pre-LCI got , if your car ( E60/61) is from 2003 ,start 2004 , your ballast and Xenon bulb won't fit the LCI headlight ( old type ballast and D2S bulb ) , but if your car is end 2004 and forward it should fit ( be able to transfer to the LCI headlights ) , due to the fact that the LCI headlight is with the "new" type of ballast and the D1S bulb.
Good luck on the project
ricki_
12
02-08-2020 09:50 PM
milhouse4u
04-22-2015 04:43 PM
rizwan1377
04-05-2015 05:22 PM
