Pre LCI Halogen to LCI Halogen harness
Hi, I really didn't want to start a new thread about the pre lci to lci as there a hundreds out there but bare with me.
As some of you might know from my other thread. I had recently purchased a used lci halogen lights to go on my pre lci 2004 e60. So i thought i make my own harness to retrofit the lci lights. As its a used lights i bought, the seller didn't bother taking out the original LCI plugs and so he just cut the wires as shown below. As i already got this, i just wanted to know what other parts/part no. do i need to complete the retrofit cable?
i read the thread that sas made but i couldn't figure out the parts needed from the diagrams on realoem.com:
https://5series.net/forums/e60-parts...ersion-103684/
Thanks for you input!
You can buy the retrofit cable from BMW for less than $40.
Part # 61120432110
I think that you are also going to need a new light control module.
E60_LCI_Retrofit.pdf
Part # 61120432110
Part # 61120432110
Attachment 145629
Part # 61120432110
Attachment 145629
To the op, basically you just need to solder the wiring into the respective wires on your car and you're done.
Though the wires in that picture is a bit puzzling to me. I don't think I have seen LCI wires with those coloring before.
That's not exactly retrofit cable. It's retrofit parts to remake the headlight harness.
Bump *sorry its just that i need an answer (if possible) to my above question as am installing the lights tomorrow and i dont want re re solder/wire
Hi! I installed it by hard wiring from the car to the harness. I didnt use the originl AE as i replaced them with orions. At that time, i used a seperate connection from the battery to operate the orions and i just removed the check for the original AEs so i dont get errors. But couple of months back, I managed to get a good deal for lm2 installed so i now run my orions directly from the car connection with out any issues. I will upload a picture as soon as i can.
