Pre-LCI DRL and welcome light mod
My Ride: 2005 525i
Read on a different forum about modifying a pre-lci headlight to run the angel eyes as drl's. I also bought a set of aftermarket LED drl's with a switchback feature so it blinks white-amber-white when I activate the turn signal. I also read about wiring the Angel eyes and the tail lights to fade on/off with the cabin lights when you lock/unlock the vehicle as sort of a welcome light. I have the instructions and procedures on how to do all this, I just need to know which wire on the headlight assembly is for the Angel eyes and the turn signal.
My Ride: 530i
My Ride: BMW 530xiT (E61)
what's the last 7 digits of your VIN? is that the harness for the left or right side that you have pictured? do you have xenons? adaptive headlights?
My Ride: 06' Range Rover Sport
I did all this on my Pre-LCI along with turn signal LED upgrade just by coding it through the former BMWhat app now iCarly. I bought the app for $60 and the Cable for $20 if I remember correctly but it was well worth it. You can diagnose your car,reset battery and more. I'm not affiliated with them in any way just thought I'd share as it was a much easier and cleaner way of doing things on my car.
Pin------------Signal------------ Function
1------------31---------------------ground
2------------56BL(R)------------left(right) HID control module
3------------56AL(R)------------left(right) high beam
4------------58VL(R)------------left(right) parking light
5------------BI_XENON-------bi-xenon solenoid signal (bi-xenon high beam reflector)
6------------49V(R)1------------front left(right) outer turn signal
7------------31--------------------ground
8------------SML-----------------voltage, side marker light
note that the wire colors on the diagrams don't match exactly (although they are close) what you've taken a picture of so I would verify this with a multimeter as I suggested previously. interestingly, I couldn't find any reference to the angel eyes/halos on their own circuit. my guess would be that they are somehow controlled by the light module based on the position of the light switch in the cabin and/or are on the same circuit as the low beam. I'm relatively new to BMW lighting, so there are probably quite a few people who have written about this elsewhere in the forum.
coding through NCS or the carly app mentioned by someone else may be your best bet.
My Ride: 2005 525i
Thanks for the bit of info! I'll play around with this and see what I can come up with. I know I can code it, but I'd like to use the aftermarket DRL's I bought as well as get that "welcome light" effect I saw somewhere else.
My Ride: 530i
im planning on taking the easy way out and try to tap into my puddle lights from my front doors and wire them to the halos as well. that way when I unlock my car, they will turn on with the interior lights lol
tnixa
10-30-2018 04:39 AM
