Pre.lci angel eye as drl help......
My Ride: 2007 530xi
Quick question seeking help.....
I need to know which wire is the 12v angel bulb supply located in the headlight harness. I dont want to tap directly to AE and have the wire run out that cap. Would be cleaner this way.
Need to know so I can then tap that line to another ACC 12v source to make AE my drls.
Thanks in advance.
Thanks in advance.
do you have xenons? If so I can check and give you an answer
(alternatively you can get an LM2 which has the ability to run the angel eyes as DRLs while also giving you welcome lights).
bestofthebest
03-28-2016 02:47 PM
umnitza
11-03-2015 02:58 PM
umnitza
09-02-2015 11:28 AM
