Pad replacement time?
Hey Gang.
The warning has now come up on my screen saying my rear pads are in need of replacement.
Is this the case?
How does the indicator system work?
Also my front pads say there is 8000 km left.
Should I change all the pads?
And does anyone know what BMW uses? Is it ATE?
Should I go aftermarket?
Many Thanks.
Is this the case?
Many Thanks.
Mate , you absolutely have to go with dustless pads like Axxis , they're even made in Aus !!
My Ride: 2004 545i - Bone stock... help!
Mine are coming up too, anyone have any experience with - http://www.ctbrakes.com/pads/bmw.html these?
I've heard/read that I need to replace rotors as well as OEM's are too thin to turn so with that said, should I replace with OEM rotors or is there a better alternative for similar price?
Originally Posted by diggydrdre' post='761280' date='Jan 6 2009, 09:23 PM
Cool Thanks.
Will the Axiis pads go okay with OEM rotors?
http://www.zeckhausen.com/bedding_in_brakes.htm
^don't forget to bed your pads after install
Originally Posted by westcoast550' post='761929' date='Jan 7 2009, 12:33 PM
Use the OEM rotors for sure but the Axxis pads will stay clean and they work brilliantly , the bedding in process is critical ....................but lots of fun !!!!!
