Out with the old ... CCC
Old May 26, 2024 | 03:43 AM
525novice's Avatar
My Ride: 2006 525d Auto SE
Default Out with the old ... CCC
Hi guys
I've got a 2006 E60 with CCC. As you will all know CCC was awful. All I want is a system that connects to my phone via Bluetooth. I presume this means removing CCC and replacing with a CIC system. As a mature student funds are tight-ish, so can anyone recommend a decent supplier? What are the parts numbers I need?
Thank you very much for any help you can give.
Old May 26, 2024 | 03:58 AM
donpb's Avatar
My Ride: '06 530i N52
Do you mean connect to your phone for phone calls or to play music?
Old May 26, 2024 | 04:05 AM
525novice's Avatar
Hi donpb
I know my phone already connects to the CCC, I'm just really used to using Spotify and Google maps for navigation. I don't need all the bells and whistles of playing videos etc, just simply play music from my phone and use Google maps.
Old May 26, 2024 | 04:27 AM
donpb's Avatar
CCC - CIC retrofit can be very expensive. You seem like you're needing CCC-Android retrofit. Google around to find out what is available.
Old May 26, 2024 | 04:32 AM
525novice's Avatar
I know this sounds simple of me, but what exactly does a CCC Android retrofit mean? Does it mean all I need to replace is the screen on the top of the dash?
Old May 26, 2024 | 04:43 AM
donpb's Avatar
BMW CCC Wireless Apple Carplay & Android Auto Retrofit - Bavarian Automotive (bavarian-automotive.co.uk).
Old May 26, 2024 | 05:17 AM
525novice's Avatar
Thats great thank you!
Old May 26, 2024 | 07:26 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
A good retrofit already coded is going to cost around $1k. If you're wanting to do the Android unit swap Bimmerdirect is a good place to purchase. When getting an Android unit you'll want to get the one that's had the most RAM to prevent freezing. The Android unit is the easiest to install about the 2. Remember though, you'll still have the CCC unit installed so if you're trying to get rid of it completely CIC retrofit is the only way to go.
Old May 26, 2024 | 11:53 AM
BartvZessen's Avatar
My Ride: E60 Lci 530i
Engine: N53
what is your opinion about the aliexpress android units?
RnrdTheFox
Aug 2, 2022 02:16 PM
Bank$hot530
Jan 20, 2017 11:48 AM
browncow
Jun 20, 2012 02:46 AM
Bklyn545i
Apr 12, 2012 10:00 AM
Tino
Mar 6, 2006 11:15 AM
