opinions on brake mods
My Ride: 2013 M5 - Sakhir Orange / Black Leather.
Originally Posted by pinguhk' post='453137' date='Jul 29 2007, 07:36 PM
sound like I got a new project.
How much are they and where can I get them?
My Ride: Mini Cooper
Originally Posted by pa550' post='453157' date='Jul 30 2007, 10:02 AM
How many steel lines are there in total for the 4 brakes?
Originally Posted by my530i' post='375803' date='Jan 9 2007, 12:18 PM
To be able to handle a bigger gun, a man must be strong enough to handle it. Is your E60 hydraulic brake system designed and ready for bigger brake? If not, you'll don't see much increase in braking performance.
That's why you see M5 hydraulic brake system is different from all other E60s because it's designed for bigger brake rotor, caliper cylinder and pads.
For a new set of brake rotor, caliper, and pads, a hydraulic brake system must be enough power to handle all new stuffs or you might not see much performance at all.
!!!!!! Disclaimer!!!!!!
All statements above are just my opinion.
Big brakes don't really make you stop faster because they're big, most stock factory brake systems are capable of locking up the wheels. Big brakes come in handy when it comes to repeated stops and improved modulation. Big rotors and calipers can hold and dissipate more heat energy, which means they stay cooler than smaller brakes doing the same amount of work. Cooler means less chance of fade and malfunction.
What I would be worried about on the e60 is screwing up all the active systems that try to keep bad drivers from killing themselves. Locked up wheels don't stop a car, so when the computer detects that the wheels are about the lock it takes steps to modulate the brakes so that the wheels are just on the threshold of locking (but still spinning). If you install big new brakes you run a very good chance of confusing that software, and creating a situation where the car doesn't brake very well when you stick the pedal to the floor.
If you'r not tracking the car you're not going to get much for you money. The difference in pads is probably all you're going to notice.
That being said, if Stoptech makes an e60 kit I would suggest using them. I really enjoy the features and feel of the kit compared to Brembo, and their markedly better than Baer and Wilwood.
Yournamehere
Buyer & Seller Feedback
11-23-2015 04:17 PM
