Open foglight
1 Attachment(s)
Hi,
Has anyone ever dissemble their foglight completely. I would like to remove the normal halogen foglight and swap in a HID+Projector inside without cutting or damaging the assembly. It has 2 clips on the projector which are easy, but I am just unsure to how undo this part without breaking anything. Has anyone done this before? Picture attached of the location giving me trouble to remove. |
It looks like the adjuster should pop out of the bracket towards the back - you may need to lift the little plastic pieces holding the ball end in.
1 Attachment(s)
Just pull it up. You can unscrew haft turn, not too much since that's the fog leveler. Also you need to be aware of the lock in place.
