Old ccc system vs cic system
My Ride: e60 528 2010
hey guys i just got my 2010 528i and after researchs i noticed that my car has the ccc idrive system and not the cic, but i do have the cic controller, and i dont have the navigation system its replaced by car data. Did i mention the screen is the small one? So any help please? I would like to know whats the differences between these two systems and if i ever wanted to change it would it cause any damage to the car? Thanks!!
My Ride: 530i
Engine: M54
wont damage the car. there are tons of threads out there documenting CCC to CIC iDrive swaps. I have CCC in my E60 and CIC in my E90, and I can tell you CIC is miles ahead of CCC.
having said that, if you were going to do anything I would just integrate some sort of mirroring device on your iDrive and just plug an iPhone into it. anything iDrive can do an up to date iphone or android phone can do better, faster, and cheaper.
My Ride: 2009 535i Sport
Model Year: 2009
Engine: N54
yeah, the CIC retrofit into an E60 just isn't worth it - it wasn't 5 years ago when the cars were worth 3X as much, and is even less worth it now. It's a few thousand dollars in hardware alone, and a PITA to tear out the dash, make sure you got all the right part #'s (and all parts have several possible part numbers based on year/model), code all the new hardware (which requires finding/downloading coding software, and hope you don't have windows XP or it won't work), then troubleshooting, etc.
I suggest you learn to live with CCC and use phone for everything you can.
No input on the mirroring, sounds like it might be worth it ... but if you can't integrate the idrive knob, steering wheel controls, etc. it sounds like a step backwards.
My Ride: 535
My Ride: 530i
Engine: M54
https://www.modmynav.com/
I have no relation with either, but both are pretty popular with the BMW crowd. Good luck.
Does the cic incoperate the same oem connections used for the ccc? I have the ccc out of my 08 with all the harness and going to install it , but if the cic utilizes the same wiring, I'll look into the cic.
My Ride: 535
If you want to use the CIC controller (I would recommend doing so), you'd need the newer trim and you'd have to repin the existing connector slightly.
CCC cars are also missing the ethernet wiring, but that doesn't seem to be used for anything important, so you can leave that out (otherwise it's 5 wires to the OBDII port).
I'm going to be running all the OEM wires and fiber optic cables from the CCC to the rear, along with for sirus and hd radio. It was an early 08 so it has the old style. I'm only running it cause it came in the car. I have all of the lci part to do this. Still determining if I want to run the speaker wires for logic 7, it's going to be work.
