Is it Okay to use 19X9.5 and 20mm Offset ?
My Ride: 535d Sport, carbon black, media pack, visibility pack, grey leather, heated seats, sun protection glass, voice control, Eibach ProKit, 19" 166 style wheels, e-maps ECU remap to 325hp and 640NM, top speed limiter removed
I would go for the second choice. (with the ET20)
My Ride: 2004 545i - 6 speed manual (July 04 build), silver-grey/black, sports package std equipment (18", active roll, active steering, adaptive headlights), premium sound, bluetooth enabled, folding rear seat, lumbar, 3m hood/bumper protective film, rear tint, euro reflectors.
Originally Posted by Mz3bo' post='330849' date='Sep 4 2006, 06:02 PM
Hi,
I am looking to buy some wheels off ebay. My car is a 04 545i.
I have the following choice combo
19X8.5 +12mm and 19X9.5 +28mm (72mm hub)
or
19X8.5 +15mm and 19x9.5 +20mm (74mm hub but will probide ring)
What do you think is the best and would not rub (with 275 in the back) if I decide to lower the car with eibach springs later on.
Thanks
or
Thanks
Although I do not like the idea of hub rings my first choice would be the 9.5 28mm for the back and the 8.5 15mm for the front.
Personally, you spent a ton of money on your car. Skip ebay and find the source for the wheels that will give you what you want.
My Ride: 2004 545i Automatic - Premium - 19" M166 - Logic 7 - No Nav
Originally Posted by jsal' post='331291' date='Sep 5 2006, 07:38 PM
The first choice is the stock 166M rims which will work. The 28mm offset for the back is PERFECT. You can even go with a 285 in back with no problems, even if you lower the car. The 12mm offset on the front will work, but IMO, I think the rim sticks out to far. It is really made for an M5 fender. Also, if you lower the car, you may have a problem with this rim. Actually, the 15mm offset of the second choice is better for the front - it kicks the rim inward a bit. No gaurantees about lowering the car with the 15mm offset. Mine are now a 14-15mm offset and it would be really close.
Many thanks for the help, I really appreciate your comment.
bestofthebest
03-28-2016 02:47 PM
umnitza
09-02-2015 11:28 AM
